2001 SX225 Ox66 Sensor voltage
  • #46
    And this will work with a DMM?
    1987 Pursuit 2200
    2001 Yamaha SX225TXRZ, 1987 Yamaha 9.9 Kicker
    • #47
      yes it will
      • #48
        So I get 200 volts to each coil from the CDI running
        1987 Pursuit 2200
        • #49
          Did you measure while the problem was happening?
          Did you get a DVA adapter or a peak meter?
          I am not sure what the book gives a minimum volts for your CDI outputs, but 200 sounds like a good number. (My C40 book calls for 140v at 1500RPM)
          • #50
            I checked it from cold start up through warm and nothing changed but am unable to get it on the water and run it to get it real hot right now.
            My local Mercury guy loaned me his meter with DVA but was only able to have it for the day.
            1987 Pursuit 2200
            • #51
              Will a bad injector cause a rich condition?
              1987 Pursuit 2200
