Did some old fashioned testing yesterday and found that #3 cylinder is not acting like the others not counting #2 (I hope theses are the two that stop firing below 1800 RPM)
I had it running and pulled the plug wires one at a time and found that #3 just barely changes when the wire is pulled, the others are very noticable when pulled and put back on so I swapped the coils and injectors with a one of the cylinders that seem to be firing strong and it made no change.
Also did a half assed spark jump test with a piece of brass rod in the plug boot and all the cylinders would jump about 3/4" inch.
