Since I'm not seeking yamaha advice, for those of you who service their own boat trailers, specifically hub/bearings, please private msg me. Thanks.
Trailer Hub Woes- Private Msg
Alright, but if I get the boot from the forum you know why. Here's what's going on. I ran into a trailer issue yesterday while on way from boat ramp to my storage facility. Noticed the left wheel wobbling. Luckily I was down the street from the facility, limped back.
I removed the tire, bearing cap, cotter pin, nut, washer. I could see the outer bearing was destroyed. The outer race is still implanted to hub. At this point I grabbed onto the hub to remove the assembly from axle, but it would not slide off. I cleaned out all of the bearing pieces and used some paper towels to clean all the gunk out to see if there was an obstruction. Nothing to note.
The hub will spin around the axle, as well as gimbal around the axle. Also, with a little muscle the hub will pull towards me about an inch, but that's it. The inner bearing seal is also intact with hub, which prevents me from seeing what's going on inside.
Since the inner bearing is intact I'm guessing it's this that has seized to the axle. I messed with it for a little then ran out of daylight. My next step was to get underneath the trailer with a heavy hammer and bang it off. Your thoughts, suggestions?Jason
Yes a big hammer and a pry bar. Try and smack it on one side while prying on the other. Picture for reference.Last edited by panasonic; 06-21-2017, 04:25 PM.
You using bearing buddies on your trailer hubs? They work good, especially on boat trailers getting dunked in the water all the time. They are inexpensive and can save you much grief...hope you get your hub off without to much trouble and that the stub axle isn't ruined.
Originally posted by panasonic View PostYou using bearing buddies on your trailer hubs? They work good, especially on boat trailers getting dunked in the water all the time. They are inexpensive and can save you much grief...hope you get your hub off without to much trouble and that the stub axle isn't ruined.
Originally posted by pstephens46 View PostBearing buddies or even better, posi-lube spindles. Grease flows from inside to out when filling to flush old grease, salt etc.
sounds like the inner bearing is stuck to the spindle and is hitting the seal as you pull on it.
I would put the wheel back on just to give you something to hold onto and add some weight to the unit.
then just grab hold and **** hard. seal should pop out of the hub allowing the the hub and tire to come off, leaving the bearing and seal on the spindle
watch your hand placement and wear gloves if close o the fender or other places to bust you hands.
all of those bearing saver things do not work if the seals go bad.
need to inspect and take care of the rust that creeps along the spindle and eats the sealsLast edited by 99yam40; 04-25-2017, 08:53 AM.
Plus 1 ^^^ and all the above.
Get access to axle after yanking the wheel. Then you can beat out races, R&R all bearings, races and seals...
Get a set cause the other side isn't much better...
Should your spindle have gotten destroyed (not likely as you caught it soon), spindles (alone) are available at Northern Tool..
I can R&R /weld a new one in your current axle, (as long as the rest of the axle isn't rusted bad)..
.Scott
Originally posted by 99yam40 View Postsounds like the inner bearing is stuck to the spindle and is hitting the seal as you pull on it.
Along with the suggestions posted here, I was also advised to use a scissor jack. Use trailer frame as base for jack and "lift" hub away from frame. Sounds like a nifty idea.
Now I have some good tricks to apply I'll give it a go this evening. Let you know the result. Appreciate the input.Jason
Originally posted by panasonic View PostYes a big hammer and a pry bar. Try and smack it on one side while prying on the other. Picture for reference.Jason
Update and finale:
I used a scissor jack and the hub popped right off, leaving behind the inner bearing exposed on spindle. Torched it and then hammered it off. And that's that.
Appreciate all of the help!Jason
Originally posted by pstephens46 View PostHow does the spindle look?
Jason
ÂÂÂÂÂÂÂ
