Originally posted by Jason2tpa
View Post
Here is how to find them:
- Clean all grease off the axle with rags.
- with clean paper towels, spray axle with brake-clean and wipe down. Do that twice.
- Get a big fat sharpie (I like red), and color the whole axle with marker and let dry.
- now try and fit your clean bearing on and it will rub the sharpie off when it hits a high spot. File or sand the high spot until the bearing will past the spot.
Rinse and repeat until bearing slides on.
A high spot of 0.001" or less will keep a bearing from sliding on.
Its either that or do like FJR1300 said get some new stub axles welded on.
Good luck Sir
