OK Maggots (and I say that with all due respect Sirs), here's the latest POOP...
[twins, both have just had the injectors serviced, new T-stats installed, new anodes installed, new racor filters installed, all fuel feed lines and clamps checked and rechecked ad nauseam, etc etc to fix my VST no fill and engine stall after prolonged idle, new lift and high psi pump installed on PORT engine, whatthehellamiforgetting......here ya go...
http://www.yamahaoutboardparts.com/f...t-th28017.html THAT PROBLEM APPEARS FIXED. AXE ME IN JUNE.
After replacing the lift pump on the OTHER engine, I took the old gal out for a spin today. Here's what I found.
Instant start, smooth idle.
Rapid throttle response.
Engines ran GREAT up to 4000. Sat there for a spell.
Pegged the throttles and got 5700 out of the Port engine and 5500 out of the Stbd. Now, bear in mind that the available run is only a mile or so, perhaps two, so I had little time to mess with motor trim and tabs.
I came down off plane for traffic and then jammed them down to the stops a second time. The STBD engine gave me a bit of scheise but wound back up to 5500. The PORT went back to 5700. I hit the no wake zone and slowed.
The STBD engine bucked and spat a fair amount. Then it stumbled badly. Then it quit. Then I smelled fuel.
I tilted that mother up, and limped back home like the sore loser that I apparently am when it comes to wrenching on these engines.
Back at the dock I pulled the flywheel cover and intake plenum. There was a fair amount of fuel in the motor splash well that had dripped out of the STBD engine when I tilted it up.
The VST "breather" hoses are filling with fuel. That fuel is being delivered to the hose which leads to top of the intake plenum. That fuel is excessive and is corrupting the intake mixture, and leaking out the bottom of the plenum.
WHY am I getting this condition? I did the exact same work to two engines. One is happy as hell. The other is in full Groucho mode.
Learn me about this damn VST venting. Please. Why am I getting excess fuel to the VST? OR, is the amount normal and its just not being properly vented / directed BACK to the VST? After all, it has two nipples and hoses on its lid. My guess is that "one is for comin' and one is for goin'". Just like the old "What's the difference between a rubber and a coffin" joke.
Did I mention that the damn things wound right up initially and I had a big grin on my old grizzled mug?
