I removed my lower unit without a hitch (thankfully) and took apart the water pump and got everything removed. While looking at the top seal I noticed that one side had a tiny bit of movement.
This is my main concern but I also posted some pictures of other things that might need addressing.
Here is a close up (sorry for the blur)
Also while inspecting other parts I had some concerns. The plastic ring on top of the insert cartridge over the impeller looks chipped.
The inside of the water pump housing looks corroded or pitted.
And finally the metal insert has corrosion on it.
