Got a 2001 30hp 3 cyl 2 stroke mshz oil injected
If I pull the plug wire on cylinder 2 there is no change. It runs a bit rough at idle, gets really rough and shakes up until I'm out of the lower rpm range and I presume off the idle circuit and on the main circuit.
Compression is 135, 135, 130 on my snap off comp tester (haven't been calibrated in 10 years but the difference between is a that really matters anyways)
Spark gap tester set at 1mm produces blue spark on all cylinders, and timing light shows all cylinders firing properly.tried switching coils around to see if any difference and problem stayed on cyl 2. Tried a fresh plug and same problem
I've just got done thorough cleaning the carb once again. Soaked it for an hour, then went through all the passages with copper wire, then blew out with my compressor. Repeated this 3 times to make sure I got anything g that could have been a problem. Still made no difference. Floats are a set in spec per manual. Floats not sticking at all, closes completely when. Blowing into it upside down.
Not sure if I'm just not getting gas to cyl 2, or if to much gas and it's over killing the a/f ratio? I see u burnt gas in the exhaust. If I close the choke on cyl 2 only the motor starts to stumble and eventual dies
Running out of ideas on what to test.
this cylinders carb is also where the fuel pump is. I replaced the diaphragms a few weeks ago thinking that was the problem but that changed nothing also. I did notice rust behind the diaphragms and I cleaned that all out but didn't notice any rust in the carb bowl. The bowl is full of fuel so I take if the pump is doing its job.
Any more suggestions?
