Exactly like the diagram.
Yamaha tachograf problems please help!
Boscoe99 , Fairdeal , thanks a lot for advices and patience with me, - yes it works. The problem was the wire I don't know why ( Not brake ) , and i changed with a computer network wire and instantly works . The trim not functional but i hope i will discover the problem.
Thanks a lott, and repeating good forum and good job!
Originally posted by pubertfester View PostBoscoe99 , Fairdeal , thanks a lot for advices and patience with me, - yes it works. The problem was the wire I don't know why ( Not brake ) , and i changed with a computer network wire and instantly works . The trim not functional but i hope i will discover the problem.
Glad you got it all to work.
here's what Boscoe hath said on a prior occasion:
Command Link tachometers can show engine hours that are contained within the engines ECU. The ECU tells the CL tachometer what hours to display. Move the ECU to another motor and the hours in that motors ECU will be displayed on the tachometer.
Conventional multifunction tachometers can show hours but not as reported by the engine to the gauge. Hours are recorded within and retained within the tachometer. Move the tachometer from one motor to another and the hours remain the same.
hello,
trim not work, it is connected the pink wire ( single pink wire with white round connectors ) but i belive the signal is not going to ecm engine. what is the connector to send the trim signal to the ecm ? incomming connector for ecm engine. i identify 2 connectors white with 4 wires pinkwith black, pink with white ...etc... and 1 connector - pink and black wires( 1 connector 2 wires).
some sugestions?thanks
Originally posted by pubertfester View Postnothing about the oil presure,
The engine ECU "sees" only that the oil pressure is OK / Not OK
It does not know specific pressure values, and hence can not report them via NMEA 2000
Â
