Command Link is what Yamaha calls their NMEA 2000 network.
Yamaha tachograf problems please help!
Originally posted by pubertfester View Postit is posible to be this connector? [ATTACH]2648[/ATTACH]?
if no, what is this for?
i ask you that because i don't find the principal connector show in red in your diagram! what it is for the 2 wires who was cut?( 2 wires with isolation band near the connector from my hand)?
Originally posted by pubertfester View Postthe "Command Link" it is also nmea network? or it is just digital data from engine computer? thanke you again for the (picture)answer it was difficult to me to identify this "Command Link" plug because in wires diagram don't apear with color or someting else to recognize it.
My photo is from my 2005 - the plug on your engine may be a different color - perhaps gray - but the two wires should still be white & blue.
Those colors are the NMEA2000 standard colors for the data conductors - I am pleasantly surprised that Yamaha followed it....
i found the connector you show me exactly in your picture( blue and white wire), i connect the 6y8 tach gauge to this ( blue wire to blue, white wire to white, ) and power the 6y8 tach gauge 12V+ red wire, black to ground(12v -) from engine power, and the gauge has open but don't show me trim or engine revolution or something else ( voltage . etc..) Some sugestions please? i should connect / disconnect something else for a good function of gauge? it is posible to don 't work command link connector? Thanks in advance!
Originally posted by pubertfester View Posti found the connector you show me exactly in your picture( blue and white wire), i connect the 6y8 tach gauge to this ( blue wire to blue, white wire to white, ) and power the 6y8 tach gauge 12V+ red wire, black to ground(12v -) from engine power, and the gauge has open but don't show me trim or engine revolution or something else ( voltage . etc..) Some sugestions please? i should connect / disconnect something else for a good function of gauge? it is posible to don 't work command link connector? Thanks in advance!
They must both be "on a NMEA 2000 network".
Which means that there is a "terminating resistor" at either "end" of the data connection.
Of course Yamaha would like you to use their special wires and devices.
You could also use "standard" NMEA 2000 wiring & connectors.
I suppose you could just do it with common wire and techniques.
But you need to include 2 resistors -IIRC, each 60 ohm.
Google up how a NMEA 2000 network works.
With respect to engine trim, you need to find the two single pin connectors having pink wires and usually being connected together with yellow tape. Remove the tap and the caps to the connectors. Then attach the two together.
NMEA 2000 resistors are 120 ohms. If measured the circuit will indicate 60 ohms. The resistors are in parallel.
hello, i belive was not so difficult to connect a tach to engine, but is, so .....
need last hand help, i have the gauge and the small cable who connect to this, and the engine, what should buy to make this tach function well, i don't want to expand the network to others gauges - i wont just this tach to indicate and that's all. it is a must have - the multi hub ? or to simplify the network it is necesary just a special cable for single tach and single engine? i found in google a lot of possible combinationsto make this and now i am confused.
thanks a lot!
good forum and good advice from users - good job!!!http://www.yamahaoutboardparts.com/i...ons/icon14.gif
It is not necessary to use the Yamaha multi hub - or any brand of specialized NMEA 2000 wiring/devices -
(at least probably not on the minimal "network" you desire)
but you DO have to mimic the circuitry that those devices would automatically provide!
Here is the pictorial form of what you need using "standard NMEA 2000 parts"
I will try to find /sketch the simple schematic this represents
ok, foud this in our store, just this model Starter_Kit_Lowrance_NMEA_2000.jpg could be ok ? it look like in your picture.
if i must do (home made ) the network please tell me on my scheme how to connect the resistors and wires look at my schemescheme ok.jpg
resistors specifications? to the store buy any tipe of 120 ohm resistors?Last edited by pubertfester; 08-19-2016, 07:16 AM.
Originally posted by pubertfester View Postok, foud this in our store, just this model [ATTACH]2652[/ATTACH] could be ok ? it look like in your picture.
that is a NMEA "starter kit" which gives you almost everything you need
except a means to connect to the proprietary Yamaha plugs at engine and gauge
On my own Yamaha F225, I simply did away with the Yamaha connector and the end of a NMEA cable and mated with simple bullet connectors
The gauge end is a bit more challenging....
I have seen that 4-terminal plug for sale as a field-installable part - but don't have a link to a website
Or you could spend more on one of several sources's adapter wires:
https://www.amazon.com/Lowrance-Yama.../dp/B0012R2PHG
Â
