OK this may have been discussed before but I have twin F150's.
One is an 2008, the other is 2010. Both were installed new.
They seem identical in every way and today as I was changing the oil I noticed the 2010 engine says 4.7qts. with filter on the cowling. The 2008 says 5.5qts.
Now I always fill and check to be sure the final level is BETWEEN the hash marks on the stick (as per the manual) so I guess it doesn't matter too much. Just for kicks I stopped at 4.7qts., ran it for 5 minutes, waited 5 minutes, did the tilt forward and back, waited again (probably not necessary) then checked level. It was at the bottom mark. So I added a little to bring it to the mid point.
When I filled the 2008 with 5.5qts. and checked in the same manner it settled right at the mid point.
Anybody else ever ran into this?
What did Yamaha change between these 2 years to make the 2010 hold less oil?
