I bought a used 2007 Yamaha F150 and am figuring out the wiring before I put it on my boat. My issue is the controls and digital tach it came with it were from a different boat so were never actually used with this motor.
My problem is right now when I run it I get erractic rpm numbers or none and no trim indications on the digital tach. I'm not sure if the overheat or oil pressure lights are working and one (4 pin) connection from the tach is not able to connect to the motor.
My main question is where does this 4 pin Nylon Connector from the tach attach to my motor? I can find any plug that will work in the front of the engine. The Plug has these wire colors: (Grey, Pink, Black, Orange). It's hard to see but I'm holding the connector in pictures 1 and 4 below.
My tach has a single wire bundle exiting the back and the number 534 on it. The tach has (2) 4-pin nylon connectors exiting it.
Am I missing a wiring harness or something?
Which color wires do what?
Thanks guys!
Thanks guys!
