Where does this connection from my Tach go on F150?
    but
    but but
    in the infinite wisdom of Yamaha.
    there are actually two trim/oil adapters.
    one goes between the engine harness and the trim/oil harness.
    the other goes between the trim/oil harness and the tach.
    then there is a few tachs that will work but you have to know how to do a small bit O jury rigging.
    kinda like converting 8mm lebel brass to work in a center fire converted 1878 vetteli.
    but at the end of the day,if you use some kind of wire between the 4 pin engine colors I posted and the tach wire colors it works.
      Exactly what I needed! Thank you sirs.
      I'll let you know how it turns out.
