Originally posted by BaffinBay
View Post
Power tilt/trim component question F150 TLRC
Yamaha 90HP 2 Stroke (1997 TLRV)
In preparation for boating attempted to raise motor by tilt/trim switch. Motor sounded but could not lift engine. Was able to lift the engine by hand while pressing ‘up’ switch and safety locked in place.(also used the manual screw on side) The ‘down’ command resulted in no movement but ‘clicking’ at the relay area. Checked the hydraulic fluid which appeared full and tried to add Yamaha fluid but it was too full to take anymore. Did not help the problem.
Researched Youtube and checked the relays with a 12 volt light tester. The red terminal showed positive. So did the blue and green terminals. This suggested a bad tilt/trim motor. Replaced with a DB Electric model which had good reviews. After installation- no difference.
Went back to investigating the relays. Connected the blue grommet to the red power and no response. Same with green. Tried connecting green (down) to blue terminal- no response.
More online research came across a comment that the relay terminals may show voltage but may not have enough amps. ???? Should the relay unit be changed?
(also ran across a reference to a little switch behind the main swivel that can get stuck. Found nothing like that but did find a light weight plastic ‘sleeve’ that easily spins around by touch. I do not think this is involved.
Need Help! Thanks
F150-TLRC power time and tilt SHOWA 3 ram
Correction to post 14, photo, label "up relief valve". That is incorrect.
This port is for a check ball with orifice valve seat and pin. Yamaha part numbers are: 64E-4392G-00-00 valve seat, 6E5 43858-00-00 ball, 64E-4381G-00-00 pin, and 64E-43897-00-00 o-ring. Correct assembly going from right to left is valve seat, ball, pin, o-ring. The check ball side of the valve seat (the end of the seat has a tiny orifice drilling) goes into the gear pump housing. This ball is off of its seat on the "UP" command, and it is seated on the "DOWN" command. Its purpose is to allow or not allow return oil from piston movement up/down into the gear pump housing AND to direct return oil to the reservoir on the "DOWN" command. Yamaha has no specific name for this valve. The circuit has many components. This is just once part of that. The Yamaha parts drawing is a bit misleading. The correct assembly has the ball inside the housing, captured in place by the pin.
FYI I had this valve assembly in backward! I will post results of my re-re-reassmbly when completed. Parts are on the way.
ÂÂÂÂÂ
