I have a 95 C40 Yamaha that has been used primarily in salt water but always rinsed out/off. There is/was a screw head located near the front of the gear case that has badly corroded and rusted away. Its not a drain or vent screw. Anyone know what this is for and any idea on how to get it out at this point to replace ? Thanks in advance.
95 C40 Lower Unit screw rusting away
here is pic of the screws below cavitation plate. the oil fill and oil level screws are apparently made of some different type metal that doesn't rust. OB pic 2.jpgAttached FilesLast edited by ncfishhawk; 05-23-2022, 02:41 PM.
Sure looks like the LU oil fill screw.
The one way up high, is that not a vent for filling?.. (#16 the fil l plug, #14 the drain plug)..
Also, that part sticking out is likely a magnet.
Part #15 shows a gasket..
https://www.boats.net/catalog/yamaha...casing-drive-1
Capture.JPGScott
I was thinking magnet also to catch metal from gears and bearings, but I thought the drain screw had a magnet for that.
maybe you can find a good welder to weld a nut onto that screw so you can get it out and replaced.
do the welding on the inside of the nut.
but I am not sure where you should hook up the ground lead
drill and ease out may be the way to remove
Per the parts diagram, part #14, the drain, doesn't have a magnet. I thought too the magnet is usually on the bottom but it'd still work..
My F150, the magnet is on the bottom drain.
Capture.JPGScott
