My 175 stumbles around 1400 rpm after that it's good until I push it above 4200. Then it pukes on itself and drops in rpm. It doesn't shut completely down. I'm thinking fuel pumps. Any ideas? Thanks
Engine has not been sitting, uses non ethanol fuel with additives. Ran fine when I launched in the spring.
Backed out the fuel pump bolts and squeezed the primer bulb (engine off) and fuel dripped down the back of the pumps. Thought this might be an indicator of a bad diaphragm or is that normal? Tightened the bolts , started engine and it ran fine. Sea trial today. Plugs are clean, no carbon , not wet from excess fuel.
if they are not leaking out of the pulse port then the diaphragm should be fine.
Possibly it is leaking out of where you loosened the bolts causing the gaskets not to seal properly
You need to find out where the fuel is seeping from.
Now moved down the list, the riding mower took a dive this afternoon.
Considering draining the fluids and taking it out and start my own artificial reef program.
Hopefully you did not forget to check the oil before mowing.
Had a guy from the church I go to ask me to have a look at his after it quit.
Oil all over the place on the outside and metal flakes on oil on dip stick.
I told him it was toast and did not even try tearing it apart to see what all was bad
Drive belt on the mower. Years ago my wife was mowing and called me at the boat to tell me it stopped. I got home about an hour later and checked the oil. EMPTY. Motor locked up. Filled it with oil and took a socket and strong bar the nut on the shaft. Rocked it back and forth and it broke free. Started it, ran for 5 minutes, then changed the oil and filter again. Ran fine. Three weeks later she called again and said the carburetor fell off. When I got home it was sitting in the middle of the lawn. I opened the cowl and the STARTER was hanging by the power cable. It seems that a rod broke and blew a hole in the block and knocked the starter off. A new motor fixed the problem. Imagine that...
