You can do that, which should be ok.
But the longer you run the RF, the better. You should feel some difference in a tank, it may take 2-3 tank (depending on the size of your tank).
Once the system is fully cleaned and adjusted, I'd keep using it, just at a lower dosage as it won't be needed that strong later down the road..
I can't speak high enough of this product, it works that well...
I wouldn't adjust the idle lower than 600 in gear (If it'll even go that low)
__________________________________________________ ______________________________
BTW, the low mileage on the truck is because I usually ride the motorcycle (part of my username too-FJR1300 is a Yamaha Large Sport Tourer motorcycle). My current daily driver(a 600cc, 95HP Yamaha, 14k red line);
This bike ALWAYS has RF in it as well.. 2007, 19K miles now. Runs like a raped ape!
