I have a 1990 Pro 50. Motor had been problematic with bad compression on one cylinder, so when I got the opportunity to buy a parts motor (bad lower unit) for a steal, I grabbed it. I had my mechanic swap the power head, and things seem to be running well overall. Definitely better than the old powerhead.
Now, I was out on the weekend, first time with a few people in the boat. I couldn't get the boat to get up on plane, wouldn't go about about 4000 RPM. So I checked the specs and sure enough the timing on the box wasn't getting up to 25 degrees. I decided to go through the service manual and set everything to spec.
All went smoothly, synced carbs, adjusted throttle control etc. Set the idle screws to 1 7/8 turns out. They were set at 6 turns out initially. Started up, and it stalled. Motor will run by bringing idle speed up to around 1000 RPM, but it runs rough and will die out. Backing out the idle screws to 4 turns smooths things out a bit. Work was done in the driveway, so I'll take it down to the ramp tonight.
Things to verify: See how top end is. Should I be able to get up to 5500 RPM with myself and wife in the boat? Its a 16' Mr Pike Deluxe.
Should idle be 800 RPM with the air screws at spec, or is it normal to need a few turns out with an older motor?
Where to start checking for causes of the rough idle: I have a spare fuel pump, can swap that out. Then rebuild carbs? Order a kit, or just clean and inspect?
Thanks for your help, you guys are awesome.
If anyone needs spare parts for a 1990 Pro50, I have stuff kicking around now.
Pat
Pat
