Thank you all very much. I will check all the things you have said to, and I'll post back.
aig gap
Originally posted by TownsendsFJR1300 View PostLOL^^
tmann45, I asked because I couldn't find your exact model # under the parts site above. That usually means the engine isn't from / in the US.
Did you find the part in question on the link I posted?
ok, no problem, s happens!Scott
Originally posted by timsullivan View PostIt's the pulser coil. I'm in the US bought the motor new in 2000 it's a 1999 60 hp C 60tlry OR tlrx not sure marks are old and faded.
Motor won't accelerate well. Fuel system is all new tank, hoses, filters, 10 micron filter, and carbs professionally cleaned. New fuel.
ring free and stabil since 2000
Starts well, idles well no missing, accelerate and it bogs down, but doesn't die. runs at 1500 rpm smoothly
I believe it was the crank position sensor like Rod posted not pulser coil.
also check to make sure your alarm system is working properly.
Could be you are having overheat putting into RPM reduction and you buzzer is not sounding. It limits RPM to about 2000
Not sure on that C60 but my C40 retards timing to limit RPM when overheat switch closes. so it is easy to check with timing light.
Do you have gauges that would indicate an alarm ?
Originally posted by rodbolt17 View Postanyone notice the specs for the #3 pulser coil?
Only one crank position sensor also.
Hee hee.
Originally posted by rodbolt17 View Post99 caught it.
that CDI system uses two pulser coils and a CPS to make spark on 3 cylinders.
Hee hee.
Rod or Boscoe does this motor retard timing or miss fire spark plugs duing the RPM reduction mode?
ÂÂÂÂÂÂÂÂ
