Hi everyone. Long time fisherman and first time boat owner. My uncle has passed down his boat to me as he hasn't used it in over 10 years.
I drained the gear oil, replaced the spark plugs, replaced the prop, replaced the main oil, new gas filters etc.
Hooked the muffs up to the outboard and cranked her over and was able to get her to fire.. I had to adjust the idle screw a tad as it wanted to stall out. Now she only dies every once in a while when going from neutral to forward or reverse. I adjusted the screw that links all 3 carbs and allows the engine to rev so it will stay running.
Road the boat for about 2 hours yesterday and she did well and then the outboard started feeling sluggish. It would all of a sudden get power again and then slug again so I trailered her home. Acted almost like it was flooding. Pulled the cowl and sure enough fuel is spitting out the top of the outboard.
Fellow at the lake said possible bad gasket causing the flooding issue.
Not sure on the year of the outboard. I just know when she isn't flooding she runs real well!
Hoping someone here can point me in the right direction.
