OK, finally got a trash bin to add water to. Here is how it's running now with a 50:1 ratio. Seems to be idling way better now that I have removed the oil injection pump.
the auto oiler should reduce the oil used at idle to 100 to 1 or less and increase it to 50 to 1 at WOT.
running 50 to 1 all the time will make it smoke more at idle
Thanks, good to know. I can now adjust the idle so low it sounds like an engine with a cam in it, but it still runs and doesn't quit on me anymore. I think i got it dialed in now. I just need to adjust the oil mixture in the future so it doesn't smoke so much..
