This item will simply not slip in...the bracket hits the hydraulic motor on one side (about a 1/4 inch) and on the other side (resivour) by about the same amount. I tried for about three calm hours to fit the operational unit and the unit that non operational unit (this one has the hydraulic motor removed. I kinda squeeze it in on an angle...it has about a 16th of an inch barring it to get into the bracket. So, for you guys who simply "slip it in"...i am guessing the brackets are spaced wider?
Cant get TNT unit back into the bracket!!! Im going crazy!!!
