I need to lift a 200 2 stroke off boat to change out trim motor. In the past I've used the hook that is on the motor. I was thinking about using my flywheel lifting eye but was thinking that it might not be as good for the bearings lifting that way.
Lifting from crank centerline does make it easier to hang the motor back on, though.
Any thoughts?
Any thoughts?
