Originally posted by TownsendsFJR1300
View Post
1) I would have brought it to the shop in the first place, but they were booked solid. So I bought the two parts and picked them up in advance (which they had to order, and is what they said they would need to have on hand if/when an opening came up), and was planning to try to go back to the shop later when they had time. However, when I stopped in the other day to get some 150mm top transom mounting bolts, and the head mechanic realized I had the engine off the transom, he said "Well shoot, you can replace these: just remove them with a big screwdriver, and put the new ones in "good and tight" with some grease." So that's how I even thought of doing it myself.
From what he said, I have no reason to remove the PTT since I can get to both screws because the engine is off the transom and on a hoist at the moment (at home).
Originally posted by rodbolt17
View Post
I'd have no problem taking it to a good shop, however if I can do something on my own, I don't mind that either. Also, I won't be near another good shop that I know (a place in Florida that rebuilt the carbs on my F80 when I first bought it and it purrs like a kitten) until probably February. Probably won't have the engine off the transom again until I re-power someday. And I'm leaving on a long trip with the boat in a week (this Washington shop will not have any openings before I leave)
Thanks for your help,
Northwester
