On my 2009 F115TXR, the needle on the voltage meter doesn't move when the boat is running. How can I tell if I am draining the battery or if the meter isn't working?
Battery voltage meter sits at 0 while boat runs
Originally posted by Yamaha115OB View PostTo measure battery voltage, do you mean put the voltmeter leads on the battery positive and negative connections?
And it looks like the gauge is made by Faria Corp.
Thanks, you guys.
Boscoe, on this forum, might like to buy your guage. He likes analog stuff, including paddle wheels. Too bad the boat builder didn’t use the Yamaha gauges.......I’m betting your guage sht the bed.
Originally posted by pstephens46 View Post
Yes for the leads. While running.
Does the fact that the volt meter needle and the fuel quantity needle are on zero indicate anything?
Boscoe is in the git rid of sh1t mode. Not taking on more crap.
So, with the boat not running, the voltage at the battery is 13V. With the boat running, the voltage is 14.6V. So, I guess it's charging and there is an issue with the gauge. I'll try to see if I can get under the dash and measure the voltage at the gauge.
Originally posted by 99yam40 View Postyou are right and on the correct path
or is it you are correct and on the right path
Some gauge panels are simply held in place with a few screws. Before you start contorting yourself, it's sometimes easier to just remove the panel. Obviously you know better than us - just throwing that out there in case you were overlooking it.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Thanks for the tip about taking the panel off...saved me a lot of time and maybe a hip replacement. So, does anyone know which leads go to the voltage meter? As you can see in the photos, there are four wires. Black, blue, purple and pink. This gauge shows the fuel level also...and it works. The key wasn't on in my previous photo and that is why the fuel gauge was zero.
ÂÂÂÂÂ
