I have a 2004 Yamaha 4 stroke 60/40 jet outboard, for the second time the number 4 cylinder was filled with gas, to the point where it wouldn’t turn over. The gas can portable has a vent cap, always left open, check twice. I can’t figure out why all the fuel pressure. How bad is that, with the cylinder filled, I take the plug out and drain, then start the motor. Starts right up, any ideas????. This ones got me, check the vent cap, its clear.
Excessive fuel pressure
The engine is a "normal" OB configuration correct(just a jet drive lower unit)?
With the #4 cylinder being the lowest cylinder sounds (as noted above), like fuel leaking into the cylinder.
As we don't have the MODEL # for the machine, a carb needle leaking, bad float-leaking, would allow fuel into the cylinder.
If fuel injected, a stuck open injector would allow the entire fuel rail to empty (gravity)to the #4 cylinder.
A little more info on the model, if FI'ed, carbureted, etc would help..
This 2004, 60 HP, 4 stroke is carbureted: https://www.boats.net/catalog/yamaha...jrc/carburetorLast edited by TownsendsFJR1300; 07-05-2019, 08:10 AM.Scott
Originally posted by jerseyjimk View PostIts a carburetor motor, yes its a 60/40 jet, the power head is 60hp. Would it be just the #4 cylinder carb or anyone of them for flooding the # 4 cylinder
You may try disconnecting the fuel line to the #4 carb for a day or two and see if you get a "full cylinder" (just to confirm)
About the only way for the carb to fill the cylinder is if the needle and /or needle seat inside the carb is leaking or float is leaking staying open.
You can inspect / clean #4 carb, test the sealing of the needle/seat with a vacuum gauge hooked to the inlet of the carb while it's held upside down. It SHOULD hold A VACUUM when closed..Scott
Each carb goes to each cylinder so it would have likely have to be the #4 carb. IDK if there's any hoses for the choke but likely not.
ÂÂÂÂ
