Bottom carb on a 2002 150 TXRA. The passage I cannot get to unclog is between the common fill passage and one of the needle valves. The passage cannot be accessed to get a tool in there for manual removal. When this passage was manufactured there is a brass press in plug where the tooling entered the cast.
So far I have tried:
CRC carb cleaner
CRC brake cleaner
Acetone
Long (multiple intervals summing up to hours in total) heated ultrasonic clean in simple green at full strength.
Long (multiple intervals summing up to hours in total) heated ultrasonic clean in LA's totally awesome degreaser at full strength.
Pulling vacuum on the needle valve location at the clog I can get a very slow bleed through of fluid or air so at best the clog is 'pourus'.
Carb came off a neglected motor that sat for years so I'm not dealing w a ill' varnish or gum....this looks more like scaling (a good analogy would be mineral deposits on a leaking plumbing valve).
Otherwise, the rest of the carb is spotless. Is there a solvent that will break down dried ethanol/water/scale? Any other tricks to get the cleaned out?
CRC carb cleaner
CRC brake cleaner
Acetone
