Hi everyone. New to boating and this forum. This happened to me today while out on the water. I have a 2004 225hp 4 stroke. Located front lower part of the leg. The wire burnt a hole through the plastic while in the water. Can someone tell me what this wire is or does? Thanks in advance!
Help! Burnt wire!
Thanks for the reply. Once the wire is fixed can that plastic covering that has the hole be fixed or patched? Or would I have to replace that whole cover? Sorry I don't know anything about out boards, that was my maiden voyage. What would that specific part be called? Cheers
Originally posted by Bingobongo View PostIs this an easy fix? Could this have done any major damage to the motor? Bought this boat a week ago.....cheers mateLast edited by pstephens46; 03-30-2019, 08:05 PM.
Does the OP know what a bonding wire is for?
It connects the parts of the motor together so what the sacrificial anodes can protect those parts fro corrosion.
Those small wires should not have current from battery or motor charging system flowing thru them.
If it does the wire heats up and melts the stuff around them.
Take it to someone that knows what they are doing if you know nothing about the electrical systems
Originally posted by 99yam40 View PostDoes the OP know what a bonding wire is for?
It would seem you have a serious "short", and I would not rule out that a battery has been connected back to front in someway. Check whether the starter positive wire has come loose and touched somewhere it shouldn't. The solenoid or carbon brushes or carbon build up within the starter motor could be the culprit.
Depending on your wiring and earth or negative connections an auxiliary or dual battery could also be the culprit by providing positive to the water via some metal and it then travelled to the leg of your engine then up that burnt wire to the bulk of your " earthed ? " engine.
Sorry a bit convoluted, but a strange fault to have.
Originally posted by zenoahphobic View Post
Spot on. It would be obvious that the wire carried way too much current, loose connection would have reduced the current and if this would have been the case the heat from the resistive joint would not have travel up that wire that far (particularly near the water).
Thanks for you reply mate. It's currently at the Boat Shop getting fixed. Hopefully all issues are resolved.
The boat shop came to the conclusion that the motor didn't start because the high pressure fuel pump was faulty.
The earthing issue was something seperate. They checked all terminals and connections, replaced the high pressure fuel pump and the motor runs fine.
I have noticed they didn't replace that bonding wire, why I do not know 🤯🤬 it is quite corroded.
I live 3 hrs away from the boat shop so taking it back is a mission, could I replace that sacrificial wire myself?
Is it a special type of wire?
Originally posted by Bingobongo View PostThe boat shop came to the conclusion that the motor didn't start because the high pressure fuel pump was faulty.
I think the wire is stainless steel, to stop It corroding normally but not from passing a large current through it. It should be replaced but will it burn again?Last edited by zenoahphobic; 04-15-2019, 08:16 AM.
ÂÂÂÂ
