Originally posted by Freaky1974
View Post
Pro 50 surge , poor acceleration
Using an ultrasonic heated cleaner with a good cleaning solution will vastly increase the backyardigans chance of getting it done right. The first time. IMO.
Which is a reason why Yamaha recommends them to the mechanics that work at Yamaha dealerships. Many Yamaha mechanics in title are not much more than backyardigans in their early stages of working on Yams.
On occasion, I'll come across one that after cleaning is still in not right...
It gets pulled apart again, dunked in the cleaner (just with dish soap and water) and let er "cook"...
I've found Simple Green and water (50/50) works ok but turns the aluminum carb body "dark". The water and soap alone seems to work very well.
Metal parts, 2-3 times, plastic parts, 2x's as the cleaning fluid heats up even with the heater off...
Well worth the $, saves time and usually more thorough.Last edited by TownsendsFJR1300; 01-01-2019, 03:17 PM.Scott
Originally posted by Freaky1974 View PostFound the fuel pump gasket damaged at the pressure fitting
bolts holding the pump on the block were loose
could this cause the condition I have ?
but I do not know if that is your only problem.
fix that and run it again to see
