I’ve a ‘97 pro 50
on occasion, the motor will sputter at a high speed - it idles rough on occasion
around 3500-till about 4200 it surges
seems to be a good amount of fuel in the water when it runs.
i understand , only the top carb has idle jets ?
the other carbs - no difference when turning the mixture screws.
once, after a high speed run, and allowing the motor to idle, it stalled- the ball was soft
ive checked spark - no problems
timing is set correctly and it’s advancing.
new fuel lines and filters.
the carbs have been apart twice - spotless clean
any ideas ?
any ideas ?
