Hello everyone im pretty new here and to boating as a whole.
Me and my wife were out off the kelseytown break wall in clinton CT over the weekend when my squel alarm started squeling.
I first noticed that there was a single black box flashing near the low oil portion of the tach/gauge.
I checkes my remote (main) oil tank and it was half full.
I then pulled the cowl off to notice the small engine mounted reservoir was at the low mark.
I limped it back with the alrm blairing the whole time. The engine was smoking a little so i knew it was still feeding oil.
I was aggrevated after taking the boat out for yhe first time this your and having it go south aftet an hour .
A day or so later I went down to the docks to play around with it to find out that the pump is not sending oil to the engine mounted tank.
I pulled the sensor from the engine reservoir and slid the float up amd the alarm went off.
I then tried the manuel over ride toggle on the oil injection computer and it DID NOT fill the engine tank. I tried the manuel toggle with both engine running and switched ignition on only with no oil fill at motor tank.
I then proceeded to hook up the pump direct to 12v to hear it turning.
I then pulled the hose nipple off the oil line running to the engine tank from the remote tank/pump amd kicked the pump on amd it DID spew oil out.
At this point the pump is working correct ???? Not quite.
I then pulled the line on the remote tank between the pump and filter and kicked the pump on and it dribbled some oil out onto a rag i had on the deck..
I then put the hoses back together and ran the pump again with leads to 12v and the tank on the engine still wont fill !!!!
Heres my questions.
A. Does the little electric pump internally bypass somehow and is this happening somehow ? Maybe the line is clogged ?
B. If the line is clogged why wont the manuel overide switch turn the pump on ?
C. Whats the beat way to clear a clogged line ? I was thinking putting 80 psi or so of air thru it and see what conea out the other end. Could the little tank filter on the remote tank still be clogged and be caising issues ??
Many thanks in advance !!!
Heres my questions.
