will 87 V6 work with digital guages?
  • will 87 V6 work with digital guages?
    I was looking to upgrade my guages from the analog to the newer digital type. My question is, will the newer digital combined tach work on my motor?
    Thanks for any responses.
    David
    The multifunction tach will work but you will need adapter's to connect the wiring harness's.If you are using the gauge kit (6YR-W0035-E1-00) then use 6H0-ADPKT-93-94 adapter kit
      What does the 6YR-W0035-E1-00 tachometer rig kit include? Thanks, jps
