1987 or 1988 115 2cycle just cleaned carbs. Motor is serging when in operation at upper RPM. Runs great at around 4k but any higher then it serges. Need help
Motor is surrging
May have restriction in fuel system, check fuel hoses, fuel filters and fuel tank pickup tube. Check fuel pump on engine.
Originally posted by Gatorkiller View Post1987 or 1988 115 2cycle just cleaned carbs. Motor is serging when in operation at upper RPM. Runs great at around 4k but any higher then it serges. Need help
Obviously I'm not saying you should go to the extreme I did (buying new carb), however, I still wouldn't rule out the potential that a blockage still exist.
