I have 40lbs of fuel preasure at the fuel rail, the engine will start and die unless I play with the throttle, I had the injectors cleaned and flowed a few months ago so I dont think it's them, in neutral it will turn 5800 no problem, as soon as I put it in gear it falls on its face, if I spray either in the throttle bodies while it is bogging it takes off, so I know it is not getting enough fuel out of the injectors, the tps tests .7 at idle and 4 volts wide open,, what else con*****s the injector pulse besides the computer? I have already swapped that out and still the same, are the injectors suposed to pulse when you first turn the key to run? I thought it use to, but it does not now, any help is appreciated as I am out of ideas, thank you,
1999 ox66 250 not getting fuel out of injectors
