my 2000 OX66 saltwater o/b runs great at all speeds over an idle,BUT at idle buzzer sounds. water stream from motor seems adequate at all times & runs fine at idle too. also oil tanks full. HELP please.
warning buzzer
NATES,
If you don't already have one, get yourself a Yamaha shop manual to help you with the water pump repair job - it's best to follow the sequence of steps in there, and also torque specs.
Go to www.yamahapubs.com and they will deliver to your door (for a fee, of course).
Be sure and use a thread sealer on the lower unit bolts and water pump bolts - I use a thread sealer called Permatex 14A with Teflon - works pretty good. My shop manual calls for Loctite 572 but I could not find it except in large quantity.
Good luck,
Ken K
Â
