New F60 install complete
  • New F60 install complete
    I will be installing a new F60 on a Mexican panga soon.
    This panga is a 22' side console open skiff that weights under a 1000#
    I will need everything from a side mount remote control to steering and beyond, to be ready to launch.
    Items needed are (I think)
    Remote side control PTT w/electric harness (703 premium I believe)
    Shift cables
    Steering (rotary or rack/pinion) to include cables and a "destroyer" type wheel.
    Steering link rod.
    A digital or analog tach with hour meter.
    3 blade aluminum prop.
    Could you please list the parts and numbers that I will need, or have missed, that will get this setup ready to get wet.
    I want to stay with genuine Yamaha parts, so as to not have any warranty problems if possible.
    In addition, since I have no local dealer to purchase parts from, I would like to purchase normal replacement parts ie: fuel filter, oil filter and a water pump impeller.
    On edit: On searching parts for a F60, it lists parts for TJR and TLR models in the 60 HP range.
    Could you please explain the difference in these models.
    The model I am considering is a 60 HP 4 stroke remote steering 20" shaft (current model year)
    I am unsure about "high thrust" models....can you explain the difference please?
    On further reading, I have found the model number difference. What I need is info for the F60 TLR model as the TJR is the jet.
    Sorry more followup. Does the side mount control unit 703482071710 come with the cables included.
    703-48207-17-10 Side mount control box(comes with 16ft harness, no cables)
    (2) MAR_CABLE-xx-SC(replace xx with length cables needed) shift and throttle cable(2 required)
    6YR-W0035-E2-00 Multifunction Tach kit with hour meter, trim gauge and warning indicators.
    14-1-SS137xx(replace xx with length cable needed) Teleflex Rotary steering system(would need to call boats.net at 877-408-1499 to order)
    14-50-28551 15 inch stainless steel Destroyer steering wheel(would need to call boats.net at 877-408-1499 to order)
    Aluminum props are available in 11-25 pitch, not sure which pitch prop that boat would need with a F60 motor on it.
    Steering Link arm should come with new motor.
