If it's on back of engine it's the emergency override switch for oil pump, if oil warning comes and engine oil tank is low you can use this switch to refill engine oil tank.
refill when it gets low.
This is to help get you back to the dock without destroying the motor and then have the system fixed so that it is automatic again, that is the reason it is called the emergency override switch.
steve it is in the operators manual on page 5-9 i explained this before have a look in other thread that you started go to the link i posted it explains how it works and reset instructions.
