Installed my 23m Yamaha prop on my 1997 150 TLRV and noticed a gap between gearcase and prop. Also has no PVS plugs, is ther some type of ring to go there or is that how they sit? Other prop was flush with gearcase.
New prop, space?
Check that is has the correct rear thrust washer and fits into prop properly.
Originally posted by boats.net View PostCheck that is has the correct rear thrust washer and fits into prop properly.
How do you measure the thrust washer? thanksLast edited by skeet skeet; 03-19-2010, 01:15 PM.
Remove prop and thrust washer and see if thrust washer fits into prop, if had non Yamaha prop and now are installing a Yamaha prop thrust washer may be wrong for that prop.
Originally posted by boats.net View PostRemove prop and thrust washer and see if thrust washer fits into prop, if had non Yamaha prop and now are installing a Yamaha prop thrust washer may be wrong for that prop.
ÂÂÂÂÂÂ
