F15eshb
  • F15eshb
    I need help. Starts, idles, runs great, leaking gas bottom of carb. Took bottom housing off, clean spring and diaphram, still leaks when running. Noticed no kind of gasket on bottom. Should be ,right?
    The diaphram is the gasket, if its leaking then probably need to replace diaphram.
