ok I believe my trim motor on 40hp yamaha is ssoon to die ( I'm told I have "Dock Trim", does'nt go up if boat is moving). The Problem... 1. when I trim up it moves very slow & stalls. afew minutes later it will move again. I disconected the 2 wires from relay & wired direct to battery w/same results.
ok since this is what I'm told "Dock Trim" can I replace just the motor?
looks like there are 3 bolts. should I pull motor completely off boat to replace? for access to bolts. not sure of yr of motor the plate is gone I do believe its 1998 - 2000. with remote steering, electric start & pull start
this all assuming I have the rt diagnostic. In the years 1998-2000, were the the trim motors the same, same part #?
any help....... your thoughts....... uncle b
