I have 2 115's on Mako, starboard shows TPS voltage out of spec according to manual, also the Throttle valve opening is negative(-0.6 deg) which shows in red at Laptop diagnostic system, I just replaced both engine control cables and plan to start and adjust the set screws, doubt is weather to loosen the TPS sensor and adjust, or adjust throttle opening set screw until display shows positive?...
Background info on motor; Runs great at RPM cruise settings, arriving at spot reducing power , starboard engine stalls when it reaches neutral/idle rpm's,..
Any suggestions appreciated.
