I have a 2003 75 Hp four stroke yamamerc. My question is this: When I put the lower unit supposedly in the neutral position (opposite the shift interrupt switch) the unit is still in forward. spinning the prop at this position has resistance in clockwise rotation (viewed from prop end) and ratcheting in counterclockwise rotation. Neutral seems to be with shift cable connection as far back as possible. spinning the prop here has no resistance in either direction but turning the flywheel moves the prop counterclockwise. If this is not the proper operation, how do I adjust the shift shaft so neutral is opposite the shift interrupt switch?
Rob
Rob
