What is boats.net water pump/impeller replacement kit # for a 1997 P200TLRV outboard.. Water pressure is getting low and I will need all parts and pieces to replace old..Thank you..
Water pump/impeller kit 1997 P200TLRV
Number 18 in this diagram is the water pump repair kit Yamaha Outboard Parts 1997 P200TLRV REPAIR KIT 2 Diagram
If need to replace housing then it's 27 in this diagram Yamaha Outboard Parts 1997 P200TLRV LOWER CASING DRIVE 1 Diagram
Thanks Boats.net..That's what I was looking for was the repair kit,, I saw the pictorial view of the lower unit with all the water pump parts but did not know exactly what I needed in that view..
The repair kit #18 does not specify what comes with it,, is there somewhere that I can review the parts list of the water pump rebuild kit #18.
Thanks..
The parts listed in that diagram with a reference number associated with part comes in kit except for number 7,8 and 14 they are lower unit gasket kit. It comes with impeller, wear plate, gaskets and bolts.
ÂÂÂÂÂ
