One of my 1985,150,etxk's has a periodic tap. When I turn it's prop by hand, it grabs, then releases. Dos this sound like a bearing; is there any way to tell without taking it apart? Please Help!: Thanks for info - When fully in gear and underway tap still persist - will buy speacial tools, take apart and have a look see.
Lower Unit Tap
Look to see if there is metal fragments on bottom drain screw in gearcase which be a sign of damage inside gearcase. Check to see if prop shaft is bent.
ÂÂÂÂÂÂÂÂ
