wrapped some *****ing wire between prop and shaft. Lower unit fluid slightly cloudy. Probably damaged seal(s)?. will be pulling boat for spring makeready. It's a 2003 225hp 4 stroke. is there a seal kit or do I order individual parts? Also will be replacing water pump assemblies. purchased kik from Boats.net. Do you recommend replacing the pump plastic housing in addition to the parts in the kit? Want to have all the parts before I haul the boat. Thanks for any response.
Prop shaft seals
The is a lower unit gasket kit but will include more parts than you will need to replace prop shaft seals, better to order the 2 seals and carrier orings(number 66 and 67 in diagram).
Inspect the water pump housing, if melted or distorted then replace or if any doubt replace it.
