1955 Yamaha F50 ... 50hp Outboard 4 stroke ...Carb model
  • 1955 Yamaha F50 ... 50hp Outboard 4 stroke ...Carb model
    1995 ... Yamaha 50hp outboard engine ... model code F50 .. Four Stroke Engine ... Carb Model ... Any ideas anyone
    Have on a couple of occasions been motoring alone around the 16 - 22 knots speed and the engine has been sweet, no misfiring, no abnormal emissions (Smoking etc)
    Out the blue, the engine rev's are restricted as if the safety device has kicked in, though there is no audible buzzer warning. There doesn’t appear to be any overheating issue going on. With the engine cowling removed, the fuel filter is full and no sign of debris in the fuel filter housing.
    With regards me being inclined to think its not overheating, I can actually place my hand on the cylinder head at various positions and the temperature is uniform and it appears to be no hotter on occasions when it’s been running trouble free (not scientific I know).
    Water is pumping fine at various water outlets and when placing my hand in the flow of water it doesn’t appear to be any hotter then it has been over the many years we have owned it.
    We cannot replicate this condition when running the engine with muffs … it simply runs fine, full rev range available.
    The fuel-priming ball is as it is normally, and all cylinders appear to be effected, there is no misfiring on a particular single cylinder.
    The engine can run fine for a couple of miles/kilometres at any speed we decide to run when the onset of the fault is sudden. We cannot anticipate when it is likely to happen.
    Has anyone heard of one of these engine going into a “safe mode” when there is no apparent reason that it should. Are there any diagnostic to check out this system? … or is it likely to be some other cause you, might have heard about with these engines, and whats the fix?
    It has us baffled .. any helpful advise would be much appreciated.
    If you do not already have them get your hands on a owners manual and a service manual and read them.
    Check your alarm system to see if it is working properly and then start trouble shooting. It is either that or take it to some one that will, with the proper tools and equipment.
      If you have the Yamaha digital tach it will have the warning lights that will show you which alarm has been activated. You would to take it to your dealer to have warning system tested, it requires a special jumper lead with resistor in it to activate alarm.
        The Tachometer is Analogue and as far as I’m aware, and I could be wrong, there doesn’t appear to be any diagnostic facility on this engine, it being a 1995 MOY engine.
        I spoke to someone today and they suggested I try “if it’s possible to get hold of … ”a substitute CDi unit”. He said that the function of the “safe mode” is activated, via the CDi unit. He mentioned that it receives inputs from sensors, if the problem persists, the fault is likely to be a sensor or a physical coolant circulation blockage, as in Thermostat/Relief valve/debris etc.
        I have the Clymer manual and the service operation manual that came with the engine from new.
        With regards taking the engine to the main agents, it could well be da ja vue!
        I took the engine to the main agents a couple of years back, and seeing as the then problem would only appear when actually on the water he could never replica the fault. In the end, we managed to solve the problem ourselves and as a bye product expend a considerable amount of money.
        I was wondering if the engine going to a “Safe Mode” condition when there was not a fault, had been heard of before?
