V6 Excell lower unit
  • V6 Excell lower unit
    Hi. About the old 220 Excell. What is the tooth number of the forward gear and the pinion? The gear ratio is 1.73:1, isn't it? Is there 26 teeth in the gear and 15 in the pinion? If someone has good used ones for sale please make me an offer. Does boats.net have new ones? Are they 6G7?
    The gear ratio is 1.80:1. Here is parts list for a 1989 20 inch shaft length V6 Excell. Yamaha Outboard Parts 1989 V6 EXCEL LF LOWER DRIVE 1 Diagram
      6k7
      Hi. I meant 6K7. Sorry. What was the year when Yamaha sold 1.73 lower units? Sometime in the 80's.
        Not sure what model or year may have had a 1.73:1 gear ratio, all of the V6 I remember were around a 1.80 or 2.00.
          Old Excell lower unit
          Hi. I have now received 6G7 gears and a pinion. They are 1,73 - 15:26. But there's a new problem. I have lost a tool. Can't find the backlash indicator to double check the shimming. Could someone please have a look at the indicator to see what the distance is from driveshaft surface to the mark on the indicator. I want to fabricate that to get the job done asap.
          Thanks.
            It's about 42mm from center on drive shaft to set point on tool.
