02 TLRA 90 Oil Leak
  • 02 TLRA 90 Oil Leak
    Motor runs great with no complaints. I have a slight leak (two-stroke oil) leaking from the pivot point of the engine. Any ideas? At this point I'm thinking its the output shaft bushing but not for sure. Please see attached pics.
    Thanks, Ryan
    It's probably leaking from oil tank on engine, check oil tank and air silencer on front of carbs for oil.
      Looks like marine grease oozing fom those upper pivot poin bearings, mine does that every time I grease the pivot point zerk fitting. There's always a blob of grease there, probably helps keep the water out of the bearing. Try pumping that zerk fitting and watch that area to see it ooz out! Good Luck!
        make sure recirc hoses are hooked to silencer
          I forgot to mention that the oil tank has been removed. I'll try to find a diagram of the recirc hoses that are supposed to be hooked to the silencer ??
            I've greased that zirk several times, the grease I use is not that color. I thought the exact same thing myself. I'm almost positive its yamalube. I have heard that the output bushing/seal can cause this same issue, but can't be for sure. Thanks for the reply.
              No Oil Tank
              My outboard has had the oil tank removed by a previous owner.
                Anyone?
                Anyone else have any ideas? It's most definately two cycle oil.
                  Could it be from the oil pump area? Is the oil pump still there? If it is you need to read up on what can happen to a oil pump if there is no oil to lubricate the moving parts.
                  How about oil in the silencer pooling after the fuel mix evaporates? There is some that sprays out of the carbs when running high RPMs.
                    Oil Leak
                    Yes, the oil pump is still on the engine but is not being driven. It's only there to plug the hole. I've removed the gear.
                    I'll check the silencer....good point.
                      I have a simular oil leak from somewhere to but i dont worry about it . I tryed putting paper towls under the motor inside the cowl to find where it was dripping from but couldnt find a thing . Its not excessive enough to worry .
                        Hmmm. Interesting.
