I am in the process of replacing a head gasket and wanted to install the head with the proper tbolt ightening sequence. Does anyone have any suggestions or a recommended pattern?
Thanks,
John
The head bolts are numbered and torque specs are on head, just start at bolt number 1 and follow sequence.
Torque to half of spec torque to all bolts then start sequence over with final torque.
