Not sure what is going on. Rebuilt carbs, new filters & plugs recently.
Boat took a crap 2 weeks ago and put 2 fuel pumps on it and it ran great for several hours of use. Then head out into the ocean and a little bump from a swell and it is like it lost power when there is a load. I cannot climb a wave but it will run at 3900 rpms using 12 gallons per hour in decent water. It normally runs at 9 gallons per hour at that rpm. As I tried to get back home I would give a little gas and it seemed like the engine would intermittently try to take off then bog down like it cannot get enough spark or fuel. Something is killing its rpms. It is idleing fine but you can tell it is a little off. Any suggestions? Starting to think it might be some sort of sensor that is not working.
