Ok, harness it not going to work. I have no plug on the engine side as it is a used engine and someone apparently has cut the plug off.
I want to hook up this trim gauge and need to know if I am hooking up the right wires.
There is a pink, black, orange and gray that is taped together at the engine. I have traced the orange, black and pink to the trim sender at the mount in tnt.
My trim gauge has a yellow/red(ignition power), pink/red, orange/red, black from gauge to plug for harness. (I know the black and blue are for light)
Question: is it simple enough to just hook the black to ground, pink to pink/red, orange to orange/red for meter and splice yellow/red into my yellow switch control (that is fused)?
What is the grey wire? I shows in the rigging guide to go to the harness plug, but like I said, there is no plug end (cut off).
Adjust meter as the Clymer manual states and then I am good to go?
